Internet keeps dropping on all devices
juliehut
Chat Champion
Message 10 of 10
For the last couple of weeks, the internet is buffering and stopping on all our devices. Is it possibly the router? It's quite old now.
Julie SR Hutchison
9 REPLIES 9
Message 1 of 10
Hi @juliehut
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 2 of 10
Hello, Keith. Thank you for your offer. Can you send out any advice please? I have recently added a Wi-Fi booster, which seemed to help a bit, but sometimes I'm getting less than 1 Mbps on my mobile. This didn't happen with the old router, it just cut out and came back.
My router is in the same place and nothing else changed. I hope you can help.
Thanks again,
Julie.
Julie SR Hutchison
Message 3 of 10
Hi @juliehut
@Karl-TalkTalk has suggested that I might be able to help you.
Message 4 of 10
Hi Julie
Wi-Fi can be tricky to troubleshoot, and the speed of your Wi-Fi is only as fast as your slowest device, so if you have any old devices, laptops or tablets these can slow things down a little. There is also the position of the router thickness of the walls the signal has to travel through etc etc.
Have  a read of our article here :  https://community.talktalk.co.uk/t5/Articles/Boosting-your-Wi-Fi-performance/ta-p/2895540
If still having issues, @KeithFrench is our resident Wi-Fi expert and can really help troubleshoot Wi-Fi speed issues.
Message 5 of 10
Hello, Karl, my new router is not disconnecting at all, but it is really slow to some wireless devices. (never happened with old router)I've tried to sort it, but I get sent in circles. Can you help? Thanks for any advice,
J Hutchison.
Julie SR Hutchison
Message 6 of 10
That's great news, thanks for letting me know.
Message 7 of 10
Hello, thanks, Karl, I've just set it up and so far so good. Hopefully the family will be happy.
Julie SR Hutchison
Message 8 of 10
hi @juliehut
Your router is quite old, so I've a new router on the way to you, to see if this helps.
Divsec
Message 9 of 10
tHi @juliehut your diagnosis is probably a good one. your post has been escalated and you should hear soon.
