Itv x
Jeffhor
Message 3 of 3
Please can you tell me if I can get it Itv X on my talktalk you view box .The you view box l have was installed new in 2016.Please advise what I can do to get Itv x
Many thanks
Jeff Horton.
Message 1 of 3
The decision not to bring ITV X to the older youview boxes was down to ITV and beyond our control.
As fr8ys advises, if you give our teams a call they can discuss options for a new streaming box.
Message 2 of 3
ITV updated the app and the software they use is no longer compatible with the box hardware.
TalkTalk no longer provide boxes that record but do supply boxes that are basically streamers and have the update ITVX on them. The 4k box can record via a usb stick, but only has one tuner so you can't record a Channel and watch another.
You might find it best to retain your box to record and invest in a Roku or Amazon fire stick which also include other free to view apps such as Pluto.
If you want a TalkTalk supplied box you will need to phone and recontract with them.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
