Why has my 3rd channel disappeared from the TV guide since TalkTalk stopped ch4
Geordyboy1
Message 5 of 5
The TV guide appearing on my tv.screen has changed over the last few days in asmuch that ITV1 guide No 3 on the list of stations has disappeared. All this seems to have happened since TT stopped having X and itvhub.
4 REPLIES 4
Message 1 of 5
OK, also check directly on the TV to see if there are any issues with channels or signals.
Geordyboy1
Message 2 of 5
Thanks for the reply to my query. I was going the the tv guide on the tv which I quest is via the youview box and I could find Ch4. It had disappeared completely. It is now the following morning Tuesday 12th Dec  an I am going to try a reset on the you box to see what happen.Fingers crossed
Message 3 of 5
Have you tried a retune ?  With the recent storms playing havoc with signals and transmitters, I lost a couple of channels direct on My TV, and have had to do a couple of retunes to get them back.
Message 4 of 5
Is this directly on your TV, or via a TalkTalk box? I have moved this to the TV section for you.
