My You view box
on 23-02-2024 03:28 PM
Message 3 of 3
My You View Box all of a sudden has Failed to record my selected recordings ???
Labels:
- Labels:
Recording
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 26-02-2024 08:04 AM
Message 1 of 3
Hi Elise48
Follow the advice from fr8ys and let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-02-2024 03:45 PM
Message 2 of 3
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
