Netgem box problem
Patdav
Message 3 of 3
I received my Netgem box 2 days ago. I set it up and it has worked perfectly. Today I cannot access any app. When I press the correct button I just get a spinning logo in the centre of my screen and it runs for about 30 seconds but doesn’t take me to any app. Please help
Message 1 of 3
Hi Patdav,
Did you follow the advice from fr8ys, did this help ?
Message 2 of 3
Have you checked the internet connection on the box?
How are you connected? Wifi or ethernet? Check the connection status in settings.
Try disconnecting the box from the mains and restart the box.
If none of these work, reset the box, either from the settings or by pressing the on off button on the side of the box 5 times.
Hope this helps. Let us know how you get on.
