New TalkTalk 4k box, all worked fine at first, now getting sound only on BBC2
Sueki
Message 3 of 3
How do I restore picture to BBC2?
Message 1 of 3
Hi Sueki
Has the advice from fr8ys helped ?  Do you need any assistance ?
Message 2 of 3
Have you done a retune?
Of do then a factory reset should work. Press the button on the side 5 times.
You will use recordings if you have one in use.
