on 24-04-2024 07:15 PM
Can’t get it to work the volume ,do I have to pair it up somehow?
on 24-04-2024 08:06 PM
on 14-12-2023 02:19 PM
Check if the remote is paired correctly with your TV as follows :
Your remote control will not auto-sync with your TV or Soundbar. If you would like to adjust the volume on your TV using the TV Hub remote, you can easily set it up by following the simple steps below.
You'll now be able to switch between TV Volume mode and TV Hub volume mode by:
See if the buttons work correctly after this.
