No Tv this morning
Pasha
Message 7 of 7
Last night my TT Tv was fine.
This morning all I get on my TV is No signal, check external imputs.
I am tech savy and have tried everything. Turning the TV and box on and off, unplugging everything, including the router. On the box I can see the lights on the box going through the waking up mode but its not showing on the TV screen.
The Tv is fine as I've now put the aerial into the tv aerial socket and I have freeview.
Any help appreciated.
Lynn
6 REPLIES 6
Message 1 of 7
OK, also try another HDMI cable if possible.
If this box has failed, it cannot be replaced. TalkTalk stopped issuing these legacy youview boxes a number of years ago.
Pasha
Message 2 of 7
Yes I swapped over from HDMI port 3 to 1 and still no difference. I'll take another look later when I'm back from work.
Lynn
Message 3 of 7
Did you try another HDMI cable / port on the TV ?
Pasha
Message 4 of 7
Hi thanks for your reply, I did think of that but I can't see anything on the screen so I don't see how I can do a re-set because I couldn't see the menu?
Lynn
Message 5 of 7
How are you getting on?
Message 6 of 7
have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset lose recordings. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
