Old TV Receiver some channels now not working?
on 17-02-2024 02:23 PM
Message 6 of 6
I have the old type youview tv receiver which I use for freeview channels and recording TV programmes. For some reason some of the channels have stopped working "Now60" etc. Is this because the TV receiver that I have is no longer supported?
Labels:
- Labels:
Channels
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 REPLIES 5
on 27-02-2024 06:25 AM
Message 1 of 6
Glad you got to the bottom of it. Just as an FYI , and for anyone else reading this, as fr8ys mentioned earlier, weather has affected freeview signals in some regions. As an example, here in the northwest, I'm on the winterhill transmitter.
Samsung TV downstairs often looses Sky News and sometimes BBC News but an LG TV upstairs seems to hold onto them. So it can also depend on the quality of the Tuner also. Both TV's use an external roof aerial.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 05:53 PM
Message 2 of 6
Found out that the problem is "That's TV" channel 71 has now been removed from Freeview, maybe available at certain times through streaming?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
23-02-2024 07:52 AM - edited 23-02-2024 07:53 AM
Message 3 of 6
Ok, try a retune, but first remove the aerial and retune to clear any residual memory the box might be holding. Then reinsert the aerial and retune.
Does this help?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-02-2024 08:48 PM
Message 4 of 6
The channels are working fine on my Tv freeview and a spare freeview receiver I have.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-02-2024 05:16 PM
Message 5 of 6
No.
The weather is causing problems and channels, especially those considered minor ones, are the first to disappear. Retuning also does not help and can cause you to lose more.
You might find your TV has a stronger tuner than your box and you may be able to receive this on there
If it's missing on both you might find that your local transmitter is no longer broadcasting these channels
You can check on the Freeview website what channels you should get by inputting your postcode there.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
