TV Hub Faulty
Message 6 of 6
@Karl-TalkTalk
I've had my hub connected again for a couple of days now and have experienced no end of issues with it, such as
  • Low sound, or indeed now, no sound
  • Picture changing to letterbox rather than full screen
  • Weak Signal - aerial is fine on TV
  • On Factory reset the Android TV screen is behind what looks like a mini TV screen where the instructions for set up are.
I've tried 3 different HDMI cables and factory reset the box 3 times (once with each cable) and nothing brings the Box back to performing properly.
I can't think of anything else to try.
5 REPLIES 5
Message 1 of 6
There has been some contention with the letters that are sent out and perceived ownership of equipment, and Arne has raised this again last week with Lorraine to query the T&C's etc.
Message 2 of 6
New box arrived and went through the set up.
Strange issue with the home button not bringing up the menu correctly. It would flash briefly and disappear.
Turned off at the mains and all now working.
Attaching proof of posting now in case of issues later and I loose the original!
Still issues with the letter that is being sent out with replacement items which I'm raising again with Lorraine.
Message 3 of 6
No Problem 🙂
Message 4 of 6
Many thanks @Karl-TalkTalk
Message 5 of 6
I've requested a replacement TV HUB for you.
