TV Hub Google Assistant
Oxfordmark
Message 7 of 7
Hello
I press the microphone button on the remote and the Assistant banner pops up but no matter what I say it does nothing.
help!
6 REPLIES 6
Message 1 of 7
OK, thanks for letting me know 🙂
Message 2 of 7
Hello
 not really, but a rebooted the box and it started to work.
Message 3 of 7
did the advice from ferguson help, is all ok now?
Message 5 of 7
I edited my entire post about remote and TV. Incase you was replying to that.
Message 6 of 7
All I can suggest is that you check the instructions here:
https://community.talktalk.co.uk/t5/Articles/Setting-up-your-TalkTalk-TV-Box/ta-p/2204453
