TV Hub. Moving Apps to micro SD card
Message 3 of 3
I have installed Apps from the play store and now being nagged about being out of storage space.
I have a micro SD card installed and used the transfer apps command in the menu to move apps but none of them moved.
I uninstalled the apps, and reinstalled them but they still installed to the Hub memory, not the SD card.
How do I use the expanded memory to install apps and avoid the out of memory message?
I've removed some apps in the meantime.
Message 1 of 3
Thank you
Message 2 of 3
Hi fr8ys,
Not tested this myself, so I've asked if our PQA Team have tested this functionality, or if they can test and let me know.
If the option is available via the menu to transfer Apps, then it should work, so let's see if we can find out if there is an issue with this option.
