TV Hub
ernie66
Message 10 of 10
I have just replaced my old Youview box with the latest TV Hub, to find that when replaying a program from ITVX, Channel 4 or Channel 5, that, although I have sound, there is NO picture. Program playback from the BBC iPLAYER works just fine.
9 REPLIES 9
Message 1 of 10
Excellent, thanks for confirming.
ernie66
Message 2 of 10
Hi @Karl-TalkTalk ,
Good news, the replacement box has solved the problem and is working just fine.
Returning the faulty box.
Message 3 of 10
You're Welcome 🙂
ernie66
Message 4 of 10
Thanks @Karl-TalkTalk  great news
Message 5 of 10
I'll swap out the box in case it has a fault, a replacement is on the way.
ernie66
Message 6 of 10
Looks like I spoke too soon, the same problem has returned.
Playback on ITVX, Channel4 and Channel5 all start playing the selected program, but with sound only, NO picture.
Playback on the iPlayer works just fine.
All apps are up to date.
Message 7 of 10
Glad to hear this is working for you now.
ernie66
Message 8 of 10
Factory reset solved the issue, thanks for your help.
Message 9 of 10
Go to settings and try an app update.
If this does not work then I can only suggest a factory reset which will download the apps again which hopefully will reset them correctly.
Let us know how you get on.
