TV Plus Box
Peter_Beamish
Message 5 of 5
My TV Plus box has suddenly stopped working and programmes will not come back despite switching off the box and restarting and switching off the power and restarting. What is going on?
4 REPLIES 4
Message 1 of 5
@k-cotton
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
k-cotton
Message 2 of 5
Hi my recording box has packed in,not surprising really it's probably about 6 years old.First it stopped recording,then the apps wouldn't work and now nothing works.
There was not many recordings on it so I did a full factory reset,but it hasn't made any difference.
Message 3 of 5
Are you able to try Youview Maintenance Reset  ?
Message 4 of 5
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non-recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know as you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
