TV Remote some buttons don't work
callmesir
Message 8 of 8
I think I know the answer but looking for a bit a help from an advisor but for the past few months I've struggled with a few of the buttons on the remote I have to really press down hard to get them to work
This is the third box I have had form Talk Talk since joining them but it is the original remote as they never sent a replacement each time just a box so its well used
Can an advisor please help
7 REPLIES 7
Message 1 of 8
You're Welcome 🙂
Message 2 of 8
Thank you 👍
Message 3 of 8
i'll send out a remote to you.
callmesir
Message 4 of 8
Apologies Yes Huawei and no it doesn't work any different with new batteries the remote is worn out by the looks of it
Hopefully they have spare remotes or a replacement box
Message 5 of 8
You didn't say, which is why I asked. Thanks for clarifying. 🙂
As I said, the support team will reply as soon as they can.
callmesir
Message 6 of 8
Thanks for the quick reply but as I've said it is the Huawei You View Box and no Talk Talk have never sent a remote with any of the replacement boxes only this one with the first box
Message 7 of 8
Remotes do wear out. Does the issue persist with new batteries? The support team will pick this up as soon as they can. Assuming this is a Huawei YouView box then these are no longer available, whether they still have spare remote controls I don't know.
Anonymous User
