TV hub box for development
Hubs2024
Message 8 of 8
I have just set up my new Tv Hub box to my TV and it is constantly showing a message saying “For Development” in the top right hand corner of the screen. I’ve tried resetting the box and resetting the router but to no avail.
7 REPLIES 7
Message 1 of 8
Thanks for confirming.
Message 2 of 8
Thank you. The update worked and has removed the “for development” banner.
Message 3 of 8
Hi @Hubs2024
I'm getting reports in now that the manual software update check is working and the box is updating.  This should resolve the issue for you too.
Message 4 of 8
If you check under Settings > Device Preference > About,  the box should have defaulted to the firmware / software version 5.7.0
The later firmware has been updated.  5.7.12 - You can check if this is available to you soon.
Meanwhile, could you send me via Private Message the Google ID of your Box so our Teams can check if it is requesting the update.
The Google ID is on a sticker under the box.
Message 5 of 8
On your TV Box, can you go to Settings > Device Preferences >  About > System Update,  and see if there are any updates available.
Message 6 of 8
This has been flagged to our Devices Teams here to see if any changes have been made over the weekend.
Message 7 of 8
I'd not heard of this until last week when another customer mentioned this.
I recommended a factory reset, but it appears you have tried this.
@Karl-TalkTalk is back tomorrow and may be able to shed some light on this, but if your resetting of the box was not a factory reset, could you please try this.
Also are you using the supplied HDMI cable? If not can you try this too.
Thank you.
