on 29-03-2024 03:44 PM
I have a Talktalk plus box which records programmes but doesn't always play back, usually it does. Is this a known issue with the box?
on 02-04-2024 12:36 PM
No Problem 🙂
on 02-04-2024 12:35 PM
Hello. I didn't try any reset and the problem appears to have disappeared. I am looking at other options regarding recording eg a separate hard drive, particularly as you have outlined the limitations of a new Talktalk box.
Thanks for your help.
on 02-04-2024 07:39 AM
Did the reset help ?
on 29-03-2024 06:49 PM
Thanks. I will try the Factory reset keep recording option.
on 29-03-2024 03:54 PM
These boxes do sometimes have this issue. It's a symptom of the hard drive failing.
Sometimes this can be rectified with a maintenance reset.
(https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but if recording is important to you then you will need to try as any box provided by TalkTalk is now non recording
Hope it works and please let us know how you get on.
