Talk talk box not connecting to tv
Frustrated171223
Message 14 of 14
When we turn on the TV and the talk talk box, nothing happens.
The TV works with our fire stick and the light comes on the talk talk box and remote but nothing happens
13 REPLIES 13
Message 1 of 14
You're Welcome 🙂
Frustrated171223
Message 2 of 14
Hi Karl,
Thank you
Message 3 of 14
New box is on the way.
Frustrated171223
Message 4 of 14
Yes please
Message 5 of 14
Would you like me to send a replacement box and returns bag for the broken box ?
Frustrated171223
Message 6 of 14
Hi, we swapped for the old box and it works, obviously the fault is in the 4k box
Message 7 of 14
OK, If the HDMI cable was not the issue, the next option would be to swap out the box.
Frustrated171223
Message 8 of 14
Hi Karl.
We swapped our 4k box for our old talk talk box, and it works..
How old box was replaced as it doesn't access itv x , but it's better than one that doesn't work at all
Message 9 of 14
Can you try unplugging the HDMI cable at both ends then plug back in to make sure it's seated correctly. If you have another HDMI cable, try this to rule out a faulty cable.
Frustrated171223
Message 10 of 14
Sadly nothing happens
Message 11 of 14
If you change the source channel with the TV Remote, and go through the HDMI sources, can you see the input from the box ?
Frustrated171223
Message 12 of 14
Message 13 of 14
What model TV box do you have ?
