Talktalk tv hub
Aaron-Olli48
Message 2 of 2
I have tried contacting Talktalk several times now on help with connecting my tv hub to satellite channels. When I previously had the same wire into my tv it worked absolutely fine now I plug in to my hub box and cannot find any channels at all. Can I get some help with this please.
A James
1 REPLY 1
Message 1 of 2
the TV box does not receive satelite channels, only freeview.  Channels such as Sky movies etc are delivered via the Now tv app.
When you mention a satelite connection, do you have a satelite dish or external aerial. The box will only connect to a terrestrial aerial.
