4k box buffers when using iPlayer catchup
Martinfdifa
Message 10 of 10
When watching catch up eg iPlayer, using the 4k box, it is constantly buffering every few minutes.
I have switched off and rebooted everything, TV, 4k box, router but no difference. I have tried switching from Ethernet to Wi-fi but no difference.
However, if I use the catchup facility through the smart TV Wi-fi, the programmes play with no buffering whatsoever.
This would seem to suggest that the 4k box is the route cause of the buffering.
Can anyone offer any solution, other than a faulty 4k box?
9 REPLIES 9
Message 1 of 10
That does sound like progress, and thanks for the feeback regarding Iplayer.
Martinfdifa
Message 2 of 10
Hi Karl,
Since replacing the router, the playback is much improved. The ‘circle of doom’ hasn’t appeared but on iPlayer, it does ‘skip’ every few minutes, which is annoying but I can live with it.
One point is that on BBC, if the programme has started and I use the option to re-start the programme, then it does still buffer every few seconds. Easily remedied, simply by waiting for the programme to end, but I thought that you ought to know.
As I say, the situation is very much improved and once again, thank you for your help.
Kind regards
Martin
Message 3 of 10
You're Welcome 🙂
Martinfdifa
Message 4 of 10
Hi Karl,
Thank you for your usual brilliant service. Naturally, I shall let you know how I get on with the problem once the new router is installed.
Kind regards
Martin
Message 5 of 10
The router is on the way to you.
Martinfdifa
Message 6 of 10
Hi Karl,
I’m happy to change the router but, as I said, there doesn’t seem to be an issue when viewing directly on the smart tv using wi-fi. However, if you think it is worth trying, I’m prepared to take your advice.
Kind regards
Martin
Message 7 of 10
Hi Martin,
All tests are clear, no errors showing on the line, and the sync speed of the router is at 39mb.
I think we should swap out the router to rule this out as a possible bottleneck.
That ok ?
Martinfdifa
Message 8 of 10
Hi Karl,
It seems to be all catch up (both via Ethernet and wi-fi) when played through the 4k box.
I initially thought that it was intermittent broadband, but when I play them through the smart tv, using even wi-fi, there is no buffering.
Kind regards
Martin
Message 9 of 10
Do any of the other players on the box buffer over wifi or is it limited to Iplayer ?
