Tv Hub takes ages to connect to TV
Milliemoomoo
Message 14 of 14
My TV hub has been working fine for months but all of a sudden it has started taking between 5 and 7 minutes to connect to the TV. You can see the screen flicker like its cycling through and trying to connect but it just keeps doing it until eventually it catches. I contacted TT on chat twice and they had me unplu and re plug the box which worked for half an hour then it returned to the same issue. Also they had me do a factory reset which again worked for a short time but the problem still persists. No cabling or other set up has changed and I have checked the router signal and thats fine. I think the box may be failing.
Please can anyone help
13 REPLIES 13
Message 1 of 14
You're Welcome 🙂
Message 2 of 14
Thanks Karl thats great
Message 3 of 14
A replacement TV HUB is on the way to you.
Message 4 of 14
Any other ideas Karl or is it a case of getting a new tv hub box - if so how do i go about doing that - thanks
Message 5 of 14
Hi Karl - tried the android reset and again it cures it for about half an hour but then it malfunctions again
Message 6 of 14
No Problem 🙂
Message 7 of 14
right thanks - i'll try that
Message 8 of 14
The full android reset is as follows :
Unplug the power cable and HDMI cable and hold down front panel button
Now plug back in the power cable and HDMI cable whilst still holding the front panel button down
Once the Android recovery screen appears you can release the button and complete a factory reset and software upgrades.
Message 9 of 14
I think so - is that the same as a factory reset using the little hole at the back
Message 10 of 14
Have you performed a full android reset ?
Message 11 of 14
Hi Karl - its the UZW4054TTG  TV hub square with round edges
Milliemoomoo
Message 12 of 14
Message 13 of 14
Which model TV Box do you have ?
