Tvx
Rupertbear
Message 3 of 3
How do I get ITX on tv to replace ITVhub?
Message 1 of 3
ITV made the decision not to bring the new ITV X App to some older devices, and this also includes the legacy TalkTalk TV Boxes.  This was a decision solely by ITV and outside of our control.
If you read our help article at ITV Hub closure - TalkTalk Help & Support
This will explain how you can upgrade to the new TV HUB.
Message 2 of 3
ITV updated the app and the software they use is no longer compatible with the box hardware. The logo has been updated from the old Hub one but it does not work.
TalkTalk no longer provide boxes that record but do supply boxes that are basically streamers and have the update ITVX on them. The 4k box can record via a usb stick, but only has one tuner so you can't record a Channel and watch another.
You might find it best to retain your box to record and invest in a Roku or Amazon fire stick which also include other free to view apps such as Pluto.
If you want a TalkTalk supplied box you will need to phone and recontract with them.
Anonymous User
