2.4 GHz band 'DOWN'
Elephants_breath
Message 7 of 7
I have enabled the 2.4 GHZ band on my router today for the first time. I am a new customer and received the router about 2 weeks ago. The router status shows the band as "DOWN" and it is not visible to devices. The band has a different SSID to the 5 GHz and is on a different channel (11 vs 44). Is this a hardware issue ?
6 REPLIES 6
Message 1 of 7
Hi Elephants_breath
That's great. If you do experience any further issues then please let us know.
Elephants_breath
Message 2 of 7
Thanks to all who replied. This is working ok now, the router just seemed to need a bit of time to sort itself out.
Message 3 of 7
Hi Elephants_breath
If you are still experiencing this issue following the factory reset then please let us know and we can send a replacement router for testing.
Message 4 of 7
Hi, I haven’t had time to re-check but will update soon. Thanks.
Anonymous User
Message 5 of 7
How are you getting on?
Message 6 of 7
What make/model of router do you have? It sounds like the first thing to do is to try a factory reset of the router's configuration.
Anonymous User
