Black Hub Setting
Pnokio
Whizz Kid
Message 74 of 74
I am still using the one I got about 3 years ago. I did get sent a new one 18 months ago. When I tried to set up the new one recently I could not get access. I was advised to do a reset but was frightened to do it incase I could not set it up. I was losing download speed but unplugged for 30 minutes fixed it.
I now have 2 Asus laptops different models both under 6 months old.
My attached images will show my problem.
George
73 REPLIES 73
Message 1 of 74
OK thanks, just let us know if you need any further assistance 🙂
Message 2 of 74
Correct. At time of my reply.
George
Message 3 of 74
Hi Pnokio,
So just to confirm, everything is OK at the moment, you don't need any further assistance?
Message 4 of 74
So just to recap: you are currently using a Sagemcom router with up-to-date software and all is working OK?
Message 5 of 74
Yes, it only took 18 months to figure that out.!!!!!!!!!!
George
Message 6 of 74
I often wondered that myself.
George
Message 7 of 74
Hi Pnokio,
The image on the left is the router that we currently supply and 174 is the latest firmware. Could I ask why you were sent the Huawei hub?
Gliwmaeden2
Message 8 of 74
The Super router and HG numbered routers that you are showing instructions for are not appropriate for the Huawei Black, @Pnokio.
Message 9 of 74
Hi Michelle, hope you understand this.
Huawei HG635 Super Router
Open your browser and type in 192.168.1.1 to go to the router admin page
Type admin into the Username and Password fields
Click Internet on the top menu bar
Click on Operating mode: and select Auto (recommended) from the dropdown menu
Select Save.
Huawei HG533 router
Click Advanced on the menu on the left
Click OK on the window that pops up
Click Advanced on the menu of the left
In the sub menu, click Connection mode
Set the Operating Mode to Auto
Click Submit
Huawei HG532 routers need to be switched to Fibre Mode manually.
On the Summary Screen click Quick Start Fibre on the left hand menu
When the page has loaded, click Connect
When the dialogue box appears, click OK
George
Message 10 of 74
Apologies for the confusion, what was the make and model of the router that you last received please? If you wanted to swap the Huawei Wifi hub for the Sagemcom wifi hub then we can do this but we would also send a routers returns bag so that the original router can be returned to us.
Message 11 of 74
so am I.
George
Message 12 of 74
I am at a total loss then, are you after a new router & if so what one, or is it an issue that needs fixing with your existing router?
Message 13 of 74
I have had a minor issue with my current model but it was fixed by being disconnected for 30 minutes and is working well at present.
Thanks any way.
George
Message 14 of 74
That will be the DG8041W. At one time it was not possible for TalkTalk to know which of the two makes you would get. Now it is only the Sagemcom FAST 5364, there is a 5464 (hub 2), but that is only on certain packages of future fibre with digital voice. Other than the voice component, they are identical.
However, let's put this another way, what router are you trying to get?
Message 15 of 74
Then why was I was sent a Huawei (model unknown) and unable to use it 18 months ago?
George
Message 16 of 74
Replaced with what 18 months ago? It is still the current router and the one that gets the most firmware upgrades. The Huawei DG8041W is about the same age & has only ever had one update. The Eero's are only available on certain packages.
Message 17 of 74
Then why did it get replaced 18 months ago.?
George
Message 18 of 74
That is the most up to date router.
Message 19 of 74
My new contract has gone live 4 days ago. I have not been contacted by TT and am still using a 3 year old Black Hub Sagemcomm.
An updated version would help a long time customer.
George
Message 20 of 74
You're Welcome 🙂
