Router Indicator Light Stopped Working
Whisper
Enlightened One
Message 16 of 16
The router that you supplied me with a while back has developed an issue, the indicator light has stopped working which isn't very helpful. Maybe the led has blown? Is it possible this can be replaced? The router model is the DG8041W. Had it maybe a couple years..
Thank you.
15 REPLIES 15
Message 1 of 16
Hi Whisper
That's great news 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Message 2 of 16
Good afternoon,
Just to let you know, I received replacement router today and old one is on it's way back to you as well. Have a wonderful weekend.
Message 3 of 16
Hi Whisper,
We look forward to hearing how you get on with the new router
Message 4 of 16
Hi Debbie,
You're a star Debbie thank you very much, I'll be sure to let you know how the connection compares. Enjoy the rest of your week.
Regards.
Message 5 of 16
Hi Whisper
Message 6 of 16
Hi Michelle,
If you could that would be very much appreciated, no idea why the led has gone on this one, it isn't that old. Thank you very much.
Anonymous User
Message 7 of 16
Would you like us to send a replacement router? Just to advise that we no longer supply the Huawei Wifi Hub so this would be a Sagemcom router instead.
Message 8 of 16
Hi there Michelle,
Light is broken, toggled the settings on/off for it as suggested there by another staff member, didn't resolve the issue. The router seems to be working fine otherwise, just that if there are any issues with my service I no longer have any indication from the router, guess I will just have to live with it the way it is. Thank you for your response.
Anonymous User
Message 9 of 16
How are you getting on?
martswain
Message 10 of 16
My solid white light failed last year, no settings made any difference, router has continued to perform normally.
It does flash orange briefly when the router starts but once a connection is established there is no solid white light.
Message 11 of 16
See if you can toggle the light on / off in the settings.
Message 12 of 16
The router seems to be working fine, broadband appears to be unaffected.
Message 13 of 16
Yes, that was the first thing I checked, thanks for your reply.
Message 14 of 16
Is the router working, ie. your internet connection is unaffected ?
Message 15 of 16
There is a setting that allows you to switch it on and off, have you checked that? Is the router otherwise working OK? The support team here should pick this up tomorrow.
Anonymous User
