Black Hub Setting
Pnokio
Whizz Kid
Message 74 of 74
I am still using the one I got about 3 years ago. I did get sent a new one 18 months ago. When I tried to set up the new one recently I could not get access. I was advised to do a reset but was frightened to do it incase I could not set it up. I was losing download speed but unplugged for 30 minutes fixed it.
I now have 2 Asus laptops different models both under 6 months old.
My attached images will show my problem.
George
73 REPLIES 73
Message 41 of 74
Hi @Pnokio
I can help with any WPS issue, what devices are you trying to connect via WPS? If you can still access the router's GUI, is WPS still enabled on both bands?
Message 42 of 74
Whoever said ' you cant teach an old dog (me) new tricks?'
George
Message 43 of 74
It will show a number whenever you are mentioned (like this, @Pnokio) or if someone likes your post. Click on your avatar then the bell image to see the relevant post.
Otherwise the number indicates a new private message. Click on the message envelope to view these.
Message 44 of 74
Why is the number 3 next to my avatar?
George
Message 45 of 74
I am not really worried about the handle as its on the router I have never used for reasons previously stated.
My new 18 month contract starts on 15 July 2023 but dont know if it includes a newer version. So will wait till then.
The router I am using just now is behaving its self.
George
Message 46 of 74
The stands are not robust, @Pnokio, and not meant to bear the weight of the router.
Slightly counterintuitive, but it means, don't use the stand as a handle. Hands on the router itself is the way to avoid this happening again.
Probably going to need a complete replacement. Staff will be back on Monday.
Message 47 of 74
Now that you have been clever enough to identify my mistake, I can go ahead using the method you described. Still don't know how to use WPS button.
One more problem, the new router I was sent and still unused, the stand became detached but not damaged. I am unable to refit it.
George
Message 48 of 74
Honestly, just reset the the router. You won't lose your connection, except briefly while the reset is actually taking place. If you need any advice after that just come back here.
Message 49 of 74
As I have not been told how to access the settings using the WPS button and unable to log in manually at this page http://192.168.1.1/2.0/gui/#/login/ I will continue to wait (18 months so far ) as I dont want to lose internet access.
George
Message 50 of 74
Bear in mind it is the router password you need, printed in very small characters on the label beneath the tab. With the username admin. Not the WiFi password.
Message 51 of 74
Please try the pinhole reset on the router. That should at least let you login to the interface using the details on the router itself.
Message 52 of 74
Yes, it is a laptop I am using. If I do not get access to the settings page, I wont be able to change the default settings.
New plan:-
is not secure
https://192.168.1.1/2.0/gui/#/login/
is even less secure. not attempted.
I entered the Router Name + Password
from the back of my router
into the 1st page above = Wrong Details
I did the same with the router I am using
It's SSID is TURBO plus my own Password
Once again = Wrong Details.
If I try using the WPS button on the router I am using now,
will it change the current log in details or change to the originals as on the rear of the router?
George
Message 53 of 74
You shouldn't need to access the router settings pages. Is it just a laptop that you are trying to connect?
Message 54 of 74
Hello Chris-TalkTalk.
Imagine I have made all the connections for my TalkTalk router correctly. I am now ready to set things up. Do I press WPS first or go to a certain web page.
I can get to the page in my image but the info it needs to give access. I have tried my personal SSID + Password, the one on the back of my currently in use router, and the new one I have which you sent 18 months ago.
If I try using WPS and do something wrong and unable to regain access, I might have to change to another ISP.
George
Message 55 of 74
To connect your PC by wifi to you router you generally would just click on the network icon on the right of your windows task bar (bottom right of your screen) - click on your router in the list and then enter the wifi password when prompted
Message 56 of 74
Contact someone who can understand a simple question. How do I set up my equipment using WPS. All you have done is tell me how to connect to my phone socket but not what to do with my PC.
George
Message 57 of 74
Could I ask what exactly are you trying to do?
Message 58 of 74
This is what your link takes me to. It does not say what to do with my PC in this case a laptop. I.E. what page should I be on or does it connect all by itself?
@Chris-TalkTalk wrote:
Hi Pnokio,
Could you take a look at the following help article and then if you need any further assistance please let us know - Wi-fi Set Up | How to Set Up TalkTalk Wi-Fi Hub | TalkTalk Help
Connect using WPS
Wi-Fi Protected Setup (WPS) lets you easily connect network equipment like wireless printers to your router. Instead of manually typing in your Wi-Fi password, you can simply press the WPS button on your Wi-Fi Hub to connect your device. Here’s how to do it:
  1. Follow the instructions that came with your device about connecting using WPS.
  2. Press the WPS button on the back of your Wi-Fi Hub until the light on the front of your Wi-Fi Hub starts flashing amber.
  3. When your device has connected to your Wi-Fi Hub, the light will turn solid white.
  4. If the connection fails, the light will flash amber again before returning to solid white.
  5. Wait until the light turns solid white and then try to connect again.
George
Message 59 of 74
Hi Pnokio,
Message 60 of 74
It seems I am not the only one who does not know how to use WPS to set it up. None of the Router Names & passwords are being accepted.
Seems I am in a feedback loop.
George
