Broadband Connection
Garry53
Message 29 of 29
Trying to post a question about connection dropping out all the time . Accussed of post flooding . Realy helpful .
28 REPLIES 28
Message 1 of 29
Hi Garry,
If you'd like us to arrange the engineer visit can you confirm:
  • Confirm your mobile number
Message 2 of 29
Yes please . Please be aware that the problem with speed / drop outs mainly occurs when the weather is wet & windy . Garry
Message 3 of 29
I'm sorry to hear that. The line test is clear and the sync speed looks consistent, however I can see that at times the SNR is dropping quite low. If all testing has been completed at the test socket with 2 different routers, cables and microfilters then the next step will be to arrange an engineer visit to the property. Would you like to go ahead with this and we can confirm some details with you?
Message 4 of 29
At the moment the speed is between 1.5 Mbps & 2.2 Mbps . Wired & WiFi . Its also raing & as usual the speed has nosedived .
Message 5 of 29
Hi Garry53
Thanks for your reply. How's the connection been since your last post?
Message 6 of 29
Yes thank you . Its on test now .
Message 7 of 29
Hi Garry53
Message 8 of 29
Hi Garry53
Message 9 of 29
I would just like a connection that stays on . If a new router achieve's this then yes . I assume if the problem still persists it would then point to a line fault .
Message 10 of 29
Hi Garry53
I can send one for testing, would you like me to arrange this?
Message 11 of 29
Not recieved one , & no mention of you sending me one . It has just dropped out again !
Message 12 of 29
Hi Garry53
Have we recently sent you a router for testing?
Message 13 of 29
Re my post made yesterday ."On the last 2 drop out the Power & Broadband on constant . Internet fast flash , Wireless & Ethernet slow flashing . " It also dropped out again last night . So stability would appear to be the same .
Message 14 of 29
Just to confirm, how has the stability been since the router has been connected to the test socket?
Message 15 of 29
The noise is there some days not others . At the moment there is no noise on the phone line .
Message 16 of 29
Hi Garry,
Do you still hear the noise on your telephone line if you disconnect the router?
Message 17 of 29
On the last 2 drop out the Power & Broadband on constant . Internet fast flash , Wireless & Ethernet slow flashing . Any ideas?
Message 18 of 29
Hi Garry53,
Does the light change on your router when the connection drops?
Message 19 of 29
The router is plugged into the test socket at the moment . The drop out occure more often when it is very windy or raining . The phone line has a crackling noise in the background as well when we are getting a lot of drop outs . The problem affects both Wi Fi and ethernet & the only way we can get the broadband back is to re-boot the router .
Message 20 of 29
I'm sorry to hear that your connection is unstable. The line test is clear, however I can see quite a few re-connections on the line and also an intermittently high number of errored seconds. Is there any noise on the voice service? Does your main socket have a test socket please?
