Broadband connection / wifi dropping / stability
koumster
Whizz Kid
Message 69 of 69
Hi Community !
Since Weds 04th December 2024 we noticed that the broadband / WIFI has been locking up and going offline and I have had to manually power off and on the router to get reconnected to the network.
Can you please check that Wifi Optimisation on my Sagemcom Fast 5364 is still DISABLED, as this was causing me problems in the past and the Wifi Optimisation was DISABLED to solve the issue.
Refer to Post made by me on ‎14-02-2024 03:00 PM (Broadband connection dropping)
68 REPLIES 68
Message 61 of 69
Hi @koumster
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
Have you connected the router directly at the test socket?
Message 62 of 69
Hi Debbie,
Yes please, as long as this router will be free of charge?
How long will it take for this router to arrive as I'd like to get these issues resolved as soon as possible. Are there any other checks/tests that can be run in the meantime, as it a total inconvenience at the moment.
Message 63 of 69
Hi @koumster
It's ok, would you like me to send a router first so we can rule this out? (as the line tests are clear)
Message 64 of 69
Hi Debbie,
Sorry, I can't remember whether I have ever been sent a new router for testing.
Message 65 of 69
Hi @koumster
The line test is clear but I can see some re connections on the line.
When did we last send you a new router for testing?
Message 66 of 69
Hi @koumster
I will run some line tests now and I will post back shortly.
Message 67 of 69
Hi Debbie,
It affects all devices, both Wifi and wired connections. The only way to get reconnected is to power cycle the router. Like I said it started happening last week and seems to be getting worse by the day.
Not sure whether this could be related to an issue with the cabling outside of the property due to the bad weather or router hardware issue.
If you check the logs for the BB connection to my property you will see how many times we've had to reboot the router
I have the following router: SagemCom (Device Ver: FAST 5364-3. T8)
Hardware Version: FAST5364 3.00
Software Version: SG4K100206
Message 68 of 69
Hi @koumster
We are no longer able to switch off WIFI optimisation on the line.
Can I just check, when you say the BB connection locks up, is this only wireless devices or is it also affecting wired connections too?
Which router do you have?
Anonymous User
