on 08-12-2024 07:43 PM
Hi Community !
Since Weds 04th December 2024 we noticed that the broadband / WIFI has been locking up and going offline and I have had to manually power off and on the router to get reconnected to the network.
Can you please check that Wifi Optimisation on my Sagemcom Fast 5364 is still DISABLED, as this was causing me problems in the past and the Wifi Optimisation was DISABLED to solve the issue.
Refer to Post made by me on 14-02-2024 03:00 PM (Broadband connection dropping)
09-12-2024 02:56 PM - edited 09-12-2024 04:00 PM
Hi Debbie,
OK, this has now been done, see attached photos
on 09-12-2024 02:32 PM
Hi @koumster
Yes please, it would be worth trying this to see if the connection remains stable. Testing at the test socket will help rule out any issues with the faceplate or internal wiring.
on 09-12-2024 02:21 PM
Hi Debbie,
thanks for confirming.
No, I have not connected the router directly to the test socket. Do you want me to do this?
on 09-12-2024 01:22 PM
Hi @koumster
I've ordered the replacement router, please allow 24-48hrs for this to arrive.
Have you connected the router directly at the test socket?
09-12-2024 01:01 PM - edited 09-12-2024 01:09 PM
Hi Debbie,
Yes please, as long as this router will be free of charge?
How long will it take for this router to arrive as I'd like to get these issues resolved as soon as possible. Are there any other checks/tests that can be run in the meantime, as it a total inconvenience at the moment.
on 09-12-2024 12:56 PM
Hi @koumster
It's ok, would you like me to send a router first so we can rule this out? (as the line tests are clear)
on 09-12-2024 12:45 PM
Hi Debbie,
Sorry, I can't remember whether I have ever been sent a new router for testing.
on 09-12-2024 12:26 PM
Hi @koumster
The line test is clear but I can see some re connections on the line.
When did we last send you a new router for testing?
on 09-12-2024 12:19 PM
Hi @koumster
I will run some line tests now and I will post back shortly.
on 09-12-2024 11:56 AM
Hi Debbie,
It affects all devices, both Wifi and wired connections. The only way to get reconnected is to power cycle the router. Like I said it started happening last week and seems to be getting worse by the day.
Not sure whether this could be related to an issue with the cabling outside of the property due to the bad weather or router hardware issue.
If you check the logs for the BB connection to my property you will see how many times we've had to reboot the router
I have the following router: SagemCom (Device Ver: FAST 5364-3. T8)
Hardware Version: FAST5364 3.00
Software Version: SG4K100206
on 09-12-2024 08:38 AM
Hi @koumster
We are no longer able to switch off WIFI optimisation on the line.
Can I just check, when you say the BB connection locks up, is this only wireless devices or is it also affecting wired connections too?
Which router do you have?
