Broadband down for 3 days and no one to speak to
manibae
Message 9 of 9
My broadband has been down for over 3 days, so called the loyalty team, after waiting in line for 10 mins, I got to speak to someone. Then I was put through to the technical team. Another hold for a few mins and got an aswering message saying they cannot answer my call. Not good at all.
8 REPLIES 8
Message 1 of 9
Hi @manibae
I've sent you a PM.
Message 2 of 9
Yes please.
Message 3 of 9
This would suggest a line issue if you are unable to call out.
The next option is to arrange an engineer for you, would you like to proceed with this now ?
manibae
Message 4 of 9
Hi Karl,
Just tested the landline and it seems we can receive calls, but cannot make calls from the landline.
There's a dial tone, and when I make a call from my mobile, it works fine, but cannot make calls from the landline to my mobile.
Message 5 of 9
are you able to borrow a handset for 2 minute to test the line.  If we send a broadband engineer and the line is at fault then they may tell you that you need a line engineer, and visa versa, somthis would risk a charge.
manibae
Message 6 of 9
Hi Karl,
Thanks for your response.
However I do not own a landline phone to test with.
The broadband is still down.
Mani
manibae
Message 7 of 9
However, I do not have a landline phone to test.
The landline is there purely for the broadband, so cannot test it, and the broadband is still down.
Message 8 of 9
As your on an ADSL service, can you connect a phone handset to the master socket or 'Test Socket' and confirm if there is a dial tone, and you are able to make and receive calls.
