Broadband download speed down from 45 Mbps to less than 2Mbps
Qwghlm
Super Duper Contributor
Message 6 of 6
Very, very slow broadband speed.
It's normally 45 Mbps now less than 2 Mbps
5 REPLIES 5
Message 1 of 6
Thanks for confirming 🙂
Qwghlm
Message 2 of 6
Just checked and it's 45.6 Mbps, so normal.
Message 3 of 6
How has the connection/speed been since your last post?
Message 4 of 6
there can be any number of reasons for this occuring, such as network maintenance by openreach to work on a nearby fault etc, it is difficult to tell retrospectively.
I have run a couple of tests on your line today and all are clear with no visible line issues.
Qwghlm
Message 5 of 6
Fixed by turning the router off then back on again.
Why does this still need to be done occasionally?
