on 09-09-2022 08:21 AM
Hi there, just recently noticed very similar threads of malfunctioning routers flashing amber with disrupted broadband.
Would appreciate assistance please, thanks!
on 14-09-2022 07:18 AM
Hi Shas333,
If you'd like us to arrange an engineer visit can you confirm:
There are information about leave in the following help article - Cancel your TalkTalk service - TalkTalk Help & Support
on 13-09-2022 07:00 PM
Hi Chris, thank you for your response. Yes, that would be much appreciated.
Could I also ask what my cancellation options are? You guys have been great but unfortunately this issue is taking rather long to resolve.
Many thanks for all your help
on 13-09-2022 01:48 PM
Hi Shas333,
If you still have no connection then the next step will be to arrange an engineer visit, If you'd like us to do this please let us know and we'll confirm some details
on 13-09-2022 01:30 PM
Hi Debbie, I have done so now and turned off the main power, allowing it approximately 2 minutes before turning it back on. However the blinking amber persists.
on 13-09-2022 01:24 PM
Hi Shas333
Thank you. Please can you connect the new router and microfilter directly at the test socket?
on 13-09-2022 01:21 PM
Hi Debbie, thank you for the response. I have managed to remove the lower section of the face plate. How should I proceed? Many thanks
on 13-09-2022 01:14 PM
Hi Shas333
This socket should have a test socket underneath the face plate.
If you gently squeeze the 2 clips on either side of the socket then the lower section of the face plate should come away.
on 13-09-2022 01:12 PM
Hi Michelle, I'm unaware as I do not use the phone line service only for WiFi. And I don't believe I do have a test socket, it is a NTE-5C socket
on 13-09-2022 12:55 PM
I'm sorry to hear this. Can I just confirm, do you have a dial tone on the voice service? Does the main socket also have a test socket please?
on 13-09-2022 12:49 PM
Hi Debbie,
I have yes, thank you. Unfortunately it continues to blink amber, and it is approaching 24 hours since start up. Would you be able to advice please?
on 13-09-2022 12:16 PM
Hi Shas333
on 09-09-2022 09:02 AM
Hi Shas333
Thank you 🙂
on 09-09-2022 09:01 AM
Thank you! I will do
on 09-09-2022 08:58 AM
Hi Shas333
on 09-09-2022 08:52 AM
Hi Debbie, thanks for the prompt reply
Yes please, a replacement router for testing would be much appreciated. Many thanks
on 09-09-2022 08:28 AM
Hi Shas333
Thank you for creating a new thread.
The line test is clear - no faults detected. Would you like me to send a replacement router for testing?
