on 05-01-2024 10:59 AM
Well after waking up the other day and having no Internet at all I hopped on my ultra slow mobile data to report this to talk talk. Now all I have. Is just a page what says track my fault and then says sorry try again in 15 minutes. After turning the router off and on for the bot first then having to do it again after I got thru the chat online. Then even after doing all that it still had a solid amber light. And then the chat was closed. And with my data on mobile being so slow I can't find out what's happening next because it must be the router at fault. But I've not heard anything from talk talk or openreach. This is terrible service the last time I was with virgin media and had a fault like this I had a repair done the same day and was even given a new router. Just the property I'm in now doesn't have access to virgin or even BT fibre.
on 17-01-2024 02:14 PM
Hi Sleepyhead
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 17-01-2024 02:09 PM
It's been fine since I have plugged in the new router. Today I also sent back the faulty router in the bag with the box just so maybe it can be fixed
on 08-01-2024 07:47 AM
Morning Sleepyhead,
Thanks for the update. How has your connection been over the weekend?
on 06-01-2024 03:50 PM
Well about 15 to 20 minutes ago the new router came I plugged all off the new ones wires for wall and power just in case and hey presto it works went to a solid white light and I checked to make sure I could connect, yep indeed, so I just have to of course send the old one that's definitely faulty with all it's cables. Thanks again Debbie I know you might not see this till Monday but thanks. Let's hope it stays working lol.
on 05-01-2024 12:12 PM
Hi Sleepyhead
Thank you 🙂
Thanks Debbie I will let you know what happens as soon as it arrives thanks again.
on 05-01-2024 12:09 PM
Hi Sleepyhead
on 05-01-2024 12:04 PM
If you can please send me a new router I can at least try it as there must be something wrong with the one I have if the line is OK?
on 05-01-2024 11:49 AM
Hi Sleepyhead
The line tests are clear, are you happy for me to go ahead and order a replacement router?
on 05-01-2024 11:43 AM
Done Debbie
on 05-01-2024 11:01 AM
Hi Sleepyhead
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
