Connection goes down many times per day. Seems to be getting worse.
alex7281
Message 6 of 6
I have a Fibre 150 contract using an MT992 Fibre modem and a Sagemcom Fast 5364-3.T8 router.
The connection has been rock solid for several years, up until a few weeks ago when it started to drop out. Sometimes it comes back by itself after a few minutes and sometimes it requires the router to be rebooted. (This has nothing to do with WiFi. The problem is with a wired connection.)
Recently the problem has been getting worse. I counted seven disconnections yesterday, but I think the true number is higher. This is making it increasingly hard to use the internet to do any serious work. Please would you look into this. Thank you.
5 REPLIES 5
Message 1 of 6
alex7281
Message 2 of 6
Thanks, will do!
Message 3 of 6
Hi Alex
alex7281
Message 4 of 6
Thank you for the quick reply.
If you think a new router might possibly fix the problem, then yes I'd be grateful if you sent one.
Thanks,
Alex
Message 5 of 6
Hi alex7281
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Would you like me to send a replacement router for testing first so we can rule this out? The next step following this will be to arrange an Openreach engineer visit.
