Constant Flashing Amber Light
Steve 1971
Message 4 of 4
Good Afternoon
My 6 month old Talk Talk Hub, Now has a constant flashing amber light.
my phone line is ok.
I've connected my old router ( which has its now issues, so is not a long term fix )
old router works i get 63mb down.
Ive done all the checks....
reset
unplugged for 20mins
checked all cables
plugged into test port on NTE 5c redone all the above.
gone though a web chat which feels like i am talking to a bot.
plus i can not access the router via its ip address..
help anyone?
3 REPLIES 3
Message 1 of 4
No Problem 🙂
Steve 1971
Message 2 of 4
@Karl-TalkTalk  thanks!!!
Message 3 of 4
i'll swap out the Hub for you and see if this helps.
