Dead Router
leosaphira
Message 8 of 8
Replacement Router last all but around 9 months (booooooo)
Can any tech folks help us get a replacement from talktalk as I not around during office hours to sit for hours on end relaying messages with my family member to a call center agent (been a deaf user)
Our router decided to give up the ghost this evening. Kicking all wifi and ethernet connections off. Router refuses to allow any connections to be made so we can not get a connection to it via ethernet or wifi (pc says unable to obtain IP address off the router)
Resetting the router via the pin hole (30secs) brings no joy
Help 🙂
Mick
7 REPLIES 7
Message 1 of 8
Hi Mick
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 8
all swapped and up and surfing again
old one sent back
thanks Debbie
Message 3 of 8
Just checking in to see if the router has arrived?
Message 4 of 8
Hi Mick
Thank you. It's a Sagemcom WIFI hub.
Debbie 🙂
Message 5 of 8
Thanks. will update when it arrives.
Hope its the red one as we had no end of issues with standard one as doesnt have enough power to transmit through the house properly.
Message 6 of 8
Hi Mick
I have ordered you a replacement router, please allow 48hrs for this to arrive.
Skynet_TX
Message 7 of 8
Hi @leosaphira,
The support team here will be back tomorrow, if they think a replacement router is necessary (and it sounds like it probably is !) then they will be able to arrange that for you.
They will hopefully be able to reply tomorrow to help.
