Dg8041w Port Forwarding 80 and 443 Issue
Nummy01
Message 6 of 6
Hi there,  after trying to setup a reverse proxy and the port forwarding not working on the router, I can see that it's a particular issue with this router. I can   also see that this router can be swapped for alternative sagemcom router. Please may I request a swap? Thanks.
5 REPLIES 5
Message 1 of 6
Hi Nummy01
Thank you 🙂
The Sagemcom hub is on its way, please allow 24-48hrs for this to arrive.
Let us know how you get on.
Nummy01
Message 2 of 6
All filled out now Debbie, thanks!
Message 3 of 6
Hi @thomaswilliams
Please can you create a new topic on the Community, I can then take a look at this for you.
thomaswilliams
Message 4 of 6
Hello. I have been having the same issues with port forwarding on my router as I am unable to port forward any port at all. Is there any chance I can also request this hub?
Message 5 of 6
Hi Nummy01
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a Sagemcom WIFI hub.
