Disable UPnP
on 21-11-2021 09:27 PM
Message 12 of 12
How do I turn off UPN for my sagecom router?
Kind of a shock the option is not there!!!!
Labels:
- Labels:
port forwarding
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
11 REPLIES 11
on 25-02-2022 10:28 AM
Message 1 of 12
I have thoroughly tested this option @Eggtastico & it definitely works OK
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2022 10:14 AM
Message 2 of 12
Glad you found it 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Message 3 of 12
doh I was being blind.
Thanks, found it. I was expecting a separate tab!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2022 10:13 AM
Message 4 of 12
I do not see the option to turn it off.
Where exactly is it?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2022 10:00 AM
Message 5 of 12
Hi Eggtastico
as Keith advises, it can be turned off from your end. We turn this off remotely but if the router is ever reset it can turn back on, so you should turn it off from the router UI.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2022 09:58 AM
Message 6 of 12
On V130, you can disable it yourself. Log into the router & go to:-
Dashboard > Manage my devices > Manage Advanced Settings > Access Control > Port Forwarding
Set Enable UPnP Igd to Off
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2022 09:55 AM
Message 7 of 12
I need to revisit this as uPNP has not been turned off. Despite Karl saying it was.
Software Version
SG4K100130 |
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-11-2021 09:36 AM
Message 8 of 12
NAT showing as disabled is just a bug, nothing more. If your ports are open then NAT is enabled.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-11-2021 09:15 AM
Message 9 of 12
UPnP is now disabled for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-11-2021 05:34 AM
Message 10 of 12
I dont actually see a firmware version, only software version :-
Hardware Version FAST5364 3.00
Software Version SG4K10002816t
GUI Version 3.7.8
Hmmm & why is NAT disabled?
NAT DISABLED
I have forwarded some ports & checking, they do seem to be open.
I still need uPnP disabled though.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-11-2021 10:00 PM
Message 11 of 12
You can only do this from firmware V130, what firmware do you have currently?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
