EERO - Poor wifi connectivity
Rambobambo
Message 5 of 5
when using eero device as a broadband router, as provided by Talktalk I am having all sorts of issues, particularly being able to connect MacBook Air and printers. This includes printers ( HP and Borthoer models) dropping off network, needing to be restarted, moved around. Also ring camera on the back wall of house  loosing wifi connection.
Can somebody please help? thanks
Raman Behl
4 REPLIES 4
Message 1 of 5
Hi @Rambobambo
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 2 of 5
Thanks, can you please send me the guide?
Raman Behl
Message 3 of 5
Hi @Rambobambo
I should be able to help you with this.
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Chris-TalkTalk
Message 4 of 5
Hi Rambobambo,
  • Name
  • Telephone number
  • Alternative contact number
