I cannot connect to my work vpn
HelenRapacioli
Message 32 of 32
I have been on with a talktalk agent for the past hour trying to solve this with no success can anyone help please - i just keep on being told talktalk do not block vpn.  However I can access it fine using hotspot or other network providers?  If it is in my admin settings just tell me what i need to do - thank you
31 REPLIES 31
Message 1 of 32
Good afternoon,
I'm sorry to hear this. I can see from your thread that you have already tested with a different router. Which VPN client are you using? Have you also contacted your IT department to see if they can offer any advice?
Message 2 of 32
Hi no still cannot connect through router- only using mobile data
Message 3 of 32
Hi Helen,
Is your VPN connection still not working?
Message 4 of 32
Hi @HelenRapacioli
My colleague Karl will have updated your router firmware to the latest version which has the fix for the previous VPN issue.
Message 5 of 32
Hi - tried again this morning and still does not connect.  What did you do to router as not sure you have details?
Helen
Message 6 of 32
Hi Helen,
I've made a change to your router, can you test now please.
Message 7 of 32
Hi - have tried that option and still does not work.  We can use mobile data so it is not the server at the company and must be related to the router/TalkTlak - what's the next step?  thank you Helen
Message 8 of 32
Hi @HelenRapacioli
I've checked again and the firmware your router is currently on is not related to the previous issue with cisco VPN.
Have you powered down the new router for a full 30 minutes to start a new session?
Message 9 of 32
You should always post directly on the community, rather than sending unsolicited messages to the support team. They will pick this up again when back online tomorrow.
Message 10 of 32
Hi Debbie - i private messaged and now messaging here.  The new router has not solved the problem - where do we go next with this?  thank you Helen
Message 11 of 32
Hi @HelenRapacioli
Message 12 of 32
Hi - done that again (did it at weekend too) - how do we go about getting me a router that works for vpn?  Thank you
Message 13 of 32
Hi @HelenRapacioli
I'm not sure why it's still not working, I'm really sorry about this.
Could you try a factory reset (pin hole reset) If it's still the same then then next step will be a replacement router.
Message 14 of 32
Hi - rebooted and still cannot connect to work vpn and still can connect via mobile data …….
Message 15 of 32
Hi @HelenRapacioli
Thanks for the Private Message.
Your router does have the correct firmware version 174. The reported issues with VPN not working was with version 202.
Could you try rebooting the router for me please?
Message 16 of 32
Hi @HelenRapacioli
Your router firmware is showing the correct version which should work with VPN.
Could you send me a Private Message with the serial number from the back of your router please?
Message 17 of 32
Hi have retested and still cannot connect.  I can connect to vpn today from home by mobile data thus is definitely the router causing the issue.
Message 18 of 32
Hi @HelenRapacioli
Thank you. I can see that your router firmware has already been changed, please can you retest again?
Message 19 of 32
Number starting 01753 is a landline number?????   Number starting 07749 is mobile
Message 20 of 32
Any update Debbie as keen to work from home tomorrow!  Thank you
