on 28-09-2023 12:55 PM
For the last week we've been suffering frequent disconnections from the internet (tho' the wi-fi remains on, with devices connected). This was confirmed using the Fast5364 hub dashboard.
I've run all the diagnostic tests (which showed no problems) and even did a full reset because it was so bad. I'm not sure if the original problem is still occurring, but the reset has re-introduced automatic wi-fi optimisation on my hub, which is causing daily havoc when it changes from my chosen channel settings (mostly on the 2.4GHz).
Could you please switch OFF the automatic wi-fi optimisation for my router?
Thanks, in advance.
on 02-10-2023 07:53 AM
Hi TTFibreuser
How's the connection been since your last post?
on 28-09-2023 01:01 PM
Hi TTFibreuser
I've switched the WIFI optimisation off as requested.
Are wired connections also dropping?
