Help with router
MClarke
Sightseer
Message 15 of 15
I have been having an issue for about two months where the router will reject access i.e. trying to connect will bring up an error message "Router refused connection"
This problem will kick me off and prevent me from getting back online.
The simple solution WAS to reset the router but now that dosn't seem to work either. I have to reset it four or five times to get the conection back andeven then it might only last twenty minutes before I'm back to square one.
14 REPLIES 14
Message 1 of 15
I'm really glad to hear this and thanks for confirming 🙂
Message 2 of 15
Yes, the connection seems to be ok now, thank you
Message 3 of 15
Sorry, I wanted to give it a few days to make sure. Yes the connection seems to be good now
Message 4 of 15
Morning @MClarke
Is your connection now working ok?
Message 5 of 15
Hi MClarke,
Openreach have now cleared and closed the fault ticket, Is everything OK at your end now?
Message 6 of 15
Hi @MClarke
The fault has been assigned to an Openreach line engineer this morning. We should hopefully have further updates later this afternoon.
Message 7 of 15
Good afternoon,
Thanks for confirming. The line test is still detecting a potential external line fault so I've passed this over to Openreach now to complete an external line investigation. We'll re-check the fault first thing in the morning and will post an update back here.
Message 8 of 15
Good morning.
Yes, there is a lack of dial tone on the voice service
There is no test socket per say.
If it helps, its a "master socker 5 C"
There is a pannel at the front that can be removed to reveal another connection inside it and I have plugged the micro filter into that to see if that works. The router and phone are also plugged into the micro filter so that should be good to go.
Message 9 of 15
Is this a wireless device that gets this error when it tries to connect to its WiFi network?
Two diffrent laptops and my phone, all of which come back with the same message
Message 10 of 15
Good morning,
Thank you. I've run a test on the line now which has detected a potential fault and the connection looks very unstable. Are you experiencing any issues with the voice service such as noise on the line or no dial tone?
Does your main socket also have a test socket please? If it does then would it be possible to connect the microfilter, router and phone directly at the test socket so we can re-run the line test again in this set up please?
Message 11 of 15
Hi @MClarke
Please can you answer the other question that I posed in my initial reply, namely:-
MClarke
Sightseer
Message 12 of 15
Account up dated Michelle
And Keith- I have the standard router talk talk gave me several years ago. I'm pretty sure I've seen a few others with the same complaint.
Message 13 of 15
  • Name
  • Telephone number or Account number
  • Alternative contact number
Message 14 of 15
What make/model of router do you have? Is this a wireless device that gets this error when it tries to connect to its WiFi network?
