Huawei HG633 - WiFi dropping
Missami1987
Message 10 of 10
The WiFi is constantly dropping out on the HG633 I have, the line to the house is all ok, but the router drops the WiFi signal at will.
I have tried to use different channels, 5Ghz, moving the equipment but no matter what is done, within minutes, the signal disappears in to the ether...
Conversations with Live Help have not helped as all the focus is on the line in to the house and not the actual router, I have a suspicion that the router needs replacing as it is a veteran now.
TALKTALK HELP PLEASE!
9 REPLIES 9
Message 2 of 10
Hi @Fiona_b1
When you have created your own thread, please feel free to @mention me into it, as I can help a lot with Wi-Fi issues.
Message 3 of 10
Hi @Fiona_b1
Please can you create a new thread/topic on the Community, we can then take a look at this for you.
Message 4 of 10
@Fiona_b1, you've posted on a very old thread, and, anyway, staff will only reply to the original poster.
Please go back to the message board and click on start a topic, near the top of the screen.
You also need to complete your community forum profile details for staff to identify your account.
Message 5 of 10
Hello. We have the same issue with our Huawei-HG633 router. It also cuts off the WiFi whenever we use the landmine but whenever we report a fault wee get told all is OK. We're on the verge of giving up and getting a new device provider but seeing this post I'm wondering if a new router my fix the issue for us too. Hope do we get one please.
Fiona
Message 6 of 10
Ok thank you for the update.
Missami1987
Message 7 of 10
All sorted thanks to a new router, as suspected, that was the issue, not location and interference.
Cheers TalkTalk
Message 8 of 10
Hi Missami1987
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
Message 9 of 10
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
