Internet cuts out on Sunday 12-1
Brassoooo15
Message 6 of 6
Hi there,
My Internet cuts out at 12 midnight like clockwork every Sunday evening. It’s usually out for at least an hour, then seems to work again. This is extremely inconvenient for me, I can see some blog posts on here that are similar, but clearly the issue still exists. Can this be fixed once and for all please?
5 REPLIES 5
Message 1 of 6
Hi Brassoooo15
How has the connection been?
Message 2 of 6
Thanks for confirming. We'll also check in with your next Monday to see how you're getting on.
Message 3 of 6
Hi Debbie,
I can see that this was automatically switched on. I have switched this off, hopefully the problem will be resolved, I will check next Sunday to see if the issue persist or not.
Pete
Message 4 of 6
Hi Brassoooo15
Please can you log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
martswain
Message 5 of 6
Check HOMEWORK TIME is OFF in the Homesafe settings.
