Internet cutting out at midnight every Sunday - unable to modify HomeSafe settings due to error
ABCroft
Message 9 of 9
Like many of your users I'm experiencing my internet dropping out for an hour periodically from midnight on Sundays despite the Hub and connection tests being fine. Similar users have apparently resolved this via HomeSafe settings, however, again like many of your users, I am also experiencing an issue where these options are unavailable and instead receive the below error message -
"There was a technical error
We’re sorry and working hard to resolve this. Please try again later."
Can you please look to resolve this access issue, or failing this, ensure there are no HomeSafe settings applied that would be causing this loss of service? Thanks
8 REPLIES 8
Message 1 of 9
Hi Fedup29
Have you checked your HomeSafe/KidsSafe settings in My Account? If you have already checked this then please can you create a new topic on the Community, we can then take a look at this for you.
Fedup29
Message 2 of 9
This is happening to me also. Homework settings and kid safe are both switched off. Every night at midnight it drops out. I am so fed up with this now. Please help
Message 3 of 9
How are you getting on? Have you checked if Homework time is switched on in your My Account under the HomeSafe settings?
Onewonderhit
Message 4 of 9
Have you checked to see if homework time is activated on your account. I turned mine off and worked fine since
Message 5 of 9
Hi @ABCroft
While this issue is still ongoing, there is a work around to stop this happening.
If you log into your router and change the DNS settings this will bypass Homesafe instructions can be found on our help page Using 3rd Party DNS - TalkTalk Help & Support
The root cause of the fault has been identified and a fix will be implemented as soon as its been tested.
Treheveras
Message 6 of 9
Sorry to say this error has been happening to me for weeks. I’ve learned that it’s a low priority as so few users are affected so a fix is taking a long time.
Why an ISP would turn the internet connection off by default and then have no way for users to change the default setting is beyond belief!
Message 7 of 9
Hi, unfortunately I can't check due to the error I referred to (attached). Is there another way to check this? Thanks
Message 8 of 9
Hi ABCroft
Please can you log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
