Internet keeps dropping
halftone
Message 3 of 3
I keep getting regular drops in internet, WiFi, lan cabled, everything just dies.
All I've done recently is move router location, same cables, same phone socket.
Its happened a couple of times a day.  Are there any checks that can be done to see maybe why all of a sudden ?
Would it be whatever this is that keeps appearing in the log ?
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Message 1 of 3
Hi halftone
Apologies for this.
I've made a change to your router firmware, please can you retest and let us know how the connection compares.
Skynet_TX
Message 2 of 3
Hi @halftone,
That entry in the log is a known issue with firmware version 1.05t on the Huawei DG8041W Wi-Fi Hub that causes the router to reboot, when the support team here return next week they will be able to upgrade your firmware to 1.06t, and that should stop the Kernel Panic errors.
