Line Dropouts
Allumri
Message 8 of 8
Been suffering from line drop outs for about the last 3 weeks. Usually speed tests indicate no problems (though if I time it correctly with a drop out, a small portion of the speed test will run down to 0.1mbps), but when I try to run a service status test I get the following message
Any help would be much appreciated.
7 REPLIES 7
Message 1 of 8
I've a different model router on the way to see if this will improve the wifi performance.
Allumri
Message 2 of 8
Thanks Karl, Still happening, as of right now;
Message 3 of 8
I've made a channel change to the wifi, see if there is any improvement with this now.  If not, we can try another router.
Allumri
Message 4 of 8
I tested this last night and had no problem with a wired connection playing xbox live.  This morning however using wireless the latency is really poor, my teams calls are dropping out every few minutes. My laptop is only 3 or 4 metres from the router so I don't believe its a distance issue.
Message 5 of 8
As soon as you test, please let us know, and our team will be here to help.
Allumri
Message 6 of 8
Hello @Debbie-TalkTalk  Thank you for coming back to me.
I've purchased a cable to check which will be delivered today - Will come back to you with more info thank you.
Message 7 of 8
Hi Allumri
I've completed a line test which hasn't detected any faults and the connection appears to be stable.
Is this affecting wired connections also or only wireless?
