My broad band speed has dropped off AGAIN.
maxthegold
Message 31 of 31
My broadband speed has dropped off again. I think this is the third time I have had this problem. It has reached the point where I am also getting dropouts, this is extremely annoying. I will post the screen grab of my monitoring so that you can see the drop. Why does this keep happening and more to the point how do I stop it?
"Outside of a dog, a book is man's best friend. Inside of a dog, it's too dark to read." Groucho Marx.
30 REPLIES 30
Message 21 of 31
If that's what it takes to fix it then do it. Don't keep asking me ridiculous questions.
Message 22 of 31
There is no noise on the telephone line when it is attached to the test socket. I am currently getting about 30 mbps. I think you are contractually obligated to supply at least 53 mbps. If it continues to drop at this rate I will soon have no broadband at all.
Message 23 of 31
Hi maxthegold,
We can arrange an engineer visit to investigate and if the telephone line is now noise free we can arrange a visit from a broadband engineer. If you'd like us to do this please let us know and we'll confirm some details
Message 24 of 31
Nobody doubts that there is something wrong, it is just wise to do as many internal tests as possible in an effort to narrow down where the problem lies. Any issue on the voice side will have an impact on the broadband connection, regardless of whether you regularly use the phone, or not. So if you could oblige one more time and advise if the noise on the line persists with just the phone  - no microfilter, router, or anything else - connected directly at the test socket that will be really helpful.
Message 25 of 31
I seem to be getting questions fired at me from 3 different people, this is very confusing and annoying. This is the third time this has happened and every time you automatically assume it is my fault and ask me to jump through hoops. Then when you can't find a way to blame me you go away and do something and everything is all right again. Can we not bypass the interim nonsense and get to the bit where you fix the problem. My setup is unchanged since the last time this happened. I don't use my landline phone more than about three times a year, it just so happens that the last time I used it was a few days ago and it was very noisy then. It is not noisy now but that may be a coincidence. I realise that noise on the line may be an indicator of a fault but the performance of my landline is not a priority, the broadband is the priority and I think I have satisfactorily demonstrated that there is something wrong there (see my posted image).
Message 26 of 31
Hi Mark
Is the noise on the line still present with the phone at the test socket and with the router removed from the line?
maxthegold
Message 27 of 31
Yes I do have a test socket and I have experienced some noise on the telephone line. I am now connected to the test socket.
Thanks,
Mark.
Message 28 of 31
Hi Mark
Do you hear the line noise when at the test socket ?
Have you tested with an alternative router / filter to rule out any hardware issued ?
maxthegold
Message 29 of 31
Thanks,
    Mark.
Message 30 of 31
I'm sorry to hear this and I will take a look now. I've run a test on the line which has detected potential fault towards the property. Can I just confirm, does your main socket have a test socket please? Is there any noise on the voice service?
