No Broadband connection
raymundo
Message 17 of 17
Been with TalkTalk for almost three years no problems always got help to sort them out
Suddenly Sagemcom router started playing up and now no connection at all just flashing red light
Done all the basics and tested router on test socket fitted by bt
I was a computer engineer so know my stuff
Router has been reset all other checks have been done  still no luck
I know TalkTalk are doing maintenance  but have left me with no connection at all for three days now what is wrong    Help
Raymundo
16 REPLIES 16
Message 1 of 17
I'm really glad to hear this and thanks for keeping us updated 🙂 I'm just sending you a short survey via a PM.
raymundo
Message 2 of 17
Hi Chris and others
Received router plugged it in hey presto now got broadband back I am so pleased I could cry 😂
Thankyou and all for your help  a huge relief
Kind regards
Raymundo
Raymundo
Message 3 of 17
raymundo
Message 4 of 17
Ok thankyou will let you know when completed test with router your sending
regards
Raymundo
Message 5 of 17
I've ordered the router and a returns bag, they should be with you within a couple of days
raymundo
Message 6 of 17
Yes no problem
Raymundo
Message 7 of 17
OK, would you like me to send one to test with? I think it's worth trying another router before arranging an engineer visit
raymundo
Message 8 of 17
No sorry no other router
Raymundo
Message 9 of 17
OK thanks. Do you have another router that you can test with?
raymundo
Message 10 of 17
Yes can confirm dial tone
Raymundo
Message 11 of 17
OK thanks. Are you experiencing any problems with your telephone service, is there a dial tone?
raymundo
Message 12 of 17
I can confirm that router is switched on  and connected to telephone line
Raymundo
Message 13 of 17
Hi Raymundo,
I'm sorry to hear that you're experiencing problems with your service. Could you just confirm that your router is currently switched on and connected to the telephone socket
raymundo
Message 14 of 17
I have updated my talktalk phone number as requested
Raymondo
Raymundo
Message 15 of 17
  • TalkTalk Telephone number
Skynet_TX
Message 16 of 17
Hi @raymundo,
The support team here will be back tomorrow and will be able to help. If they can't see any issues when they run their line tests, and if they think the router itself may be at fault, they would be able to arrange a replacement router for you.
