ORDI REQUEST?
casa22
Message 7 of 7
Whenever I go on a broadband providers website and enter my address, it says broadband/fiber is not available (even though I'm using fiber).  So I contacted BT and they said the below.  Although, I've read it should be an ORDI form TalkTalk needs to submit - to ensuring my address is gold not silver?   Either way please can you ensure it's fixed asap?  thanks.
BT:  " I can see that your address is already registered with Royal Mail. This means that your Service Provider just needs to place an order for a telephone service only. If they have any problems placing your order ask them to contact us direct and we’ll be able to assist them.
If you don’t require a telephone line and only require Broadband then your chosen Service Provider will need to place an order for Broadband only using your Silver address.
If they have any issues with placing an order please ask them to contact us directly.  "
6 REPLIES 6
Message 1 of 7
thanks Arne,  I'll keep checking and let you know
Message 2 of 7
Message 4 of 7
Thanks Arne, I'll check after 10 days then
Arne-TalkTalk
Message 5 of 7
Hi @casa22
I will request an ORDI it usually takes around 10 days to complete.
Regards.
Divsec
Message 6 of 7
Hi @casa22 your post has been escalated and you should hear soon. The team here are excellent and will get you sorted.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
